Keywords for EFT Tests (Multiband)
tha-paul
Post by tha-paul »
i am trying to generate a report for EFT Test with the report generator. Unfortunately it is not working as intended. I want to get the information in the red marked field. For example the test result for the first sequence. Which keyword do I have to use?
I have tried the following keywords:
||EFT|L1 RESULT||
||EFT|L1/L2 RESULT||
||EFT|L1/PE RESULT||
||EFT|PE RESULT||
actually I have tried all which includes the word "RESULT". None of them are working.
I use the Radimation Pro Version 2020.2.7.
Thanks and best regards
Steffen
tha-paul
Re: Keywords for EFT Tests (Multiband)
Post by tha-paul »
Ok I found the Keyword by my own :-)
Since I am using a Multiband test, the Keyword for the e.g. 1. Sequence in my case is:
||EFT|BAND1 TestStatus||
For the second sequence it would be ||EFT|BAND2 TestStatus|| and so on.
