New Version: RadiMation version 2021.1.9
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.1.8 version.
This version 2021.1.9 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.1.9 release of RadiMation can now be downloaded from the Raditeq web-site. Image
The following issues are fixed in this 2021.1.9 version (compared to the 2021.1.8 version):
  • #11666: ErrorReport: No Tooltip found for buttons placed on the graph control
  • #11693: AW: Report Generator - keyword Frequency Step and Modulation does not work
  • #11743: ErrorReport: "rbw coupling error" on HP 7405 analyser.
  • #11746: ErrorReport: "Can't auto couple sweep time in zero span" on HP 7405 analyser.
  • #11779: wxWidgets Debug Alert
  • #11782: Driver: Teseq CBA 1G-600D.
  • #11789: Editing a limit line value initially shows the unit default value scaled to the new selected unit
  • #11790: VI instrument time index axis is not updated for the additional time measured
  • #11791: Using SQL to format a custom peak table including frequency data adds the _RAW frequency column data instead.
  • #11792: RadiTower unnecessary moved to 4M after measuring at 1m
  • #11793: Error Start frequency is too low for selected equipment, when viewing the data of two tests simultaneously
  • #11794: RI Graph, no filter at top of the Graph
  • #11798: Graphs settings, Frequency Range/Scaling not possible.
  • #11816: Using order by clauses on table names results in the table not being found when the unit is missing in the keyword
  • #11817: 0,5 kV is not selectable in the EFT manual mode test
  • #11819: ESW8 Measuring input 2 @1 GHz results in error -222 data out of range
  • #11820: Using a <CUSTOM> field in the EUTInfo.ini results in the input being shifted when shown in RadiMation
  • #11826: During test initialisation a "Pause" window before action is not shown to the user
  • #11832: limit lines is using a wrong x axis scale.
  • #11833: Error report improvements.
  • #11838: Device driver for Rohde&Schwarz SMBV100B Signal Generator
  • #11839: Device driver for Rohde&Schwarz FSV3000 Spectrum Analyzer
  • #11840: Incorrect step frequency in immunity.
  • #11841: Peak number not visible in graph.
  • #11849: Reporting of antenna height incorrect during test and in review
  • #11852: Manual clamp mover driver is reporting the distance in degrees instead of centimeters
  • #11853: Manual clamp mover driver shows the distance in on 0.001 mm accuracy, which is just unlogical
  • #11859: RI logarithmic "Frequency Step" not possible to set smaler than 1%"
  • #11863: Tooltip of shown peaks uses incorrect text, higher\lower then should be higher\lower than
  • #11866: NSG4070 Does not power on at start of test.
  • #11871: TESEQ NSG 3040: Device returned Error code: 19.
  • #11872: NSG4070 failure?
  • #11878: Out of memory exception while doing EUT Save As...
  • #11884: Number of peaks not correctly applied
  • #11888: Peak detection absorbing clamp test
  • #11889: Radilog becomes unresponsive and freezes Radimation, when monitor inputs are measured during MB Pulsed testing.
  • #11890: ESW8 1000 kHz not possible with QP.
  • #11905: Changing the unit text of the combobox, does not result in the unit text being changed
  • #11915: AW: LUMILOOP LSProbe1.2, error measuring with multiple LSProbe devices
  • #11989: FW: WIki Download button driver werkt niet
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.1
