This version 2021.3.3 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.3.3 release of RadiMation can now be downloaded from the Raditeq web-site.
The following features are added to RadiMation 2021.3
- The number of vertical divisions of a graph can be configured
- Disabling continuous measure is not confusing anymore
- Expected *IDN? of the majority of device drivers can be modified
The following issues are fixed in this 2021.3.3 version (compared to the 2021.2.7 version):
- #3971: Radiated emission multiband: click on "continuous measure" to disable function is taken twice quite often.
- #6698: Project: Improve Continuous measurement method.
- #11553: Underscore shortcut keys are not correctly assigned in field probe setup dialog
- #11604: Text that is shown in progress bar is dark grey, instead of black as in buttons.
- #11612: Binary block buffer retrieval over VISA Socket port is resulting in timeout
- #11687: WriteReadBinaryBlockBuffer causes timeout when TCPIP::x.x.x.x::port::SOCKET is used
- #11742: ErrorReport: "locked the gpib board".
- #11887: Measure time of 10ms is out of range.
- #12053: The device driver system is currently not usable
- #12072: ErrorReport: "Multiband Test one subrange not executed".
- #12082: Schwarzbeck CDN as injection device
- #12083: Include a check during startup to ensure that the Windows decimal separator is not "" (blank/nothing) or "0"
- #12084: Correction file with Frequency unit in kHz only shows half of the graph
- #12106: Send frequencies above 10 GHz to newer RadiSense 10 probes.
- #12108: Control channel selection of the radio dummy/fibre optic link of RFPA
- #12129: RepGen: Using a RunMacro keyword, results in the "" keyword not found event being presented
- #12133: Magnitude graph of S-parameter test shows an additional line going to 0
- #12134: Stop sequence: sequence is not correctly aborted when stop is pressed during a zero operation.
- #12135: Frequency scale is not full span.
- #12141: Resolution of R&S ESIB can be configured but only to 500 points
- #12142: Correction file: graph not displayed
- #12146: Rigol RSA5065A without EMI option can only measure a single trace
- #12160: Provide a configuration setting in the Narda EP600-series to configure the sleep mode time.
- #12173: Virtual Signal generator enables carrier on frequency change.
- #12174: Time-out Spurious emission measurement.
- #12181: Strange error on closing RadiPower driver.
- #12185: Rigol RSA5000 series, should allow to use 0 dB attenuation in combination with preamplifier
- #12186: Rigol RSA5065: When auto preamplifier is selected, it is reported as 0 dB, even though the preamplifier is on
- #12207: Reselect the limitline in the TSF file clears the max value customization of the graph.
- #12208: Driver: Tektronix RSA 306B.
- #12216: Error message that device driver system is not usable after a RadiSense error
- #12223: Driver: Prana IPDR250
- #12224: Driver: Prana CJDR250
- #11106: Vertical scaling does not adjust (30M-1G)
- #11882: Graph ticks do not follow unit settings
- #11931: Scaling of emission plots
- #11951: Ongoing annoying issues with scaling of graphs
- #11967: Onlogische schaalverdeling Y-as
- #12024: Y-axis values are not displayed completely
- #12062: Update reseller information of NSI-MI UK
- #12085: ErrorReport: "Object reference error when creating correction files with 0.001 kHz frequencies"
- #12132: clsSettingGraphDivisions object ID not registered
- #12296: BONN BLWA amplifier initialization failed
- #1909: Use device driver out of default frequency range for similar models
- #6006: Turn off of the continuous measure is not working if long observation times are used
- #7222: Allow customization of the expected *IDN? response of drivers
- #7500: Response errors detected during the check device should be shown to the enduser in the error description
- #9106: Wrong device driver selected
- #11740: Include prefix on the suggested name of the on the exported ambient line.
- #11873: Manual Controlled AD converter is not working correctly anymore
- #11987: When the *IDN? does not match we should show a correct message
- #12215: ESIB Analyser Error: Not all bytes are written to the GPIB-Board within the timeout period
- #12247: RadiMation Crash when using ESR for QP measurements
- #12254: Issues with QP measurements too high on Rigol DSA832
- #12277: Power measurement is reported twice by configurable switchmatrix in 2021.2.7
- #12280: Driver: Keysight N9916B
- #12284: Driver: Amplifier Prana N-MT 1650D
- #12286: ForwardPowerMeasured event in switchmatrix is not raised for first 2 frequencies
- #12288: Connect RSS2010I with radimation software
- #12289: RadiSense 10 is not correctly detected
- #11896: Send filename of test results to CARAD
- #12305: An additional unlogical GPIB board is checked during startup
- #12306: Bonn amplifier driver doesn't report description of basic errors
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.3 .
