New version: RadiMation version 2021.3.8
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.3.3 version.
This version 2021.3.8 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.3.8 release of RadiMation can now be downloaded from the Raditeq web-site. Image
The following features are added to RadiMation 2021.3
  • The number of vertical divisions of a graph can be configured
  • Disabling continuous measure is not confusing anymore
  • Expected *IDN? of the majority of device drivers can be modified
The following issues are fixed in this 2021.3.8 version (compared to the 2021.3.7 version):
  • #11707: QP value of the final measurement is not updated in the peak table"
  • #11843: Regulation on Electrical Field closed loop measured by analyzer is regulating above testlevel
  • #11981: Datetime is shown in OLE format when inserting table into txt file
  • #11924: Device driver: NSG 4060
  • #11999: Switch-Matrix TESEQ RFB2000 "Incorrect switch settting"
  • #12220: Corrrection file frequency list does not take unit precision in considereation
  • #12273: Correction of spectum analyzer
  • #12298: Peak measurement of radiated emissions measurement is too high
  • #12345: EFT Multiband, stop and return to "Automatic" last test perform twice.
  • #12348: EFT Test: NX5, error before every start.
  • #12358: Surge, EM-Test NX5, EXT coupling not working.
  • #12414: High peaks during the conducted emission measurements
  • #12422: Polarization Incco 3000
  • #12466: 4395A spectrum analzyer read out error during CS test
  • #12475: 337 dBuV is returned when retreiving trace data
  • #12476: Radiated emission test failed.
  • #12477: Precision on Logaritmic frequency step
  • #12481: problems connecting to Filedsensor Raditeq RSS2010I
  • #12483: spectrum analyzer overflow
  • #12486: Timeout with configurable AD Converter
  • #12491: Probe rotator hangs while moving to 120 degrees
  • #12492: Detector is not correctly set.
  • #12495: NSLK8122RC controlled by ESR via radimation ????
  • #12497: Issues at KEMA with RadiSense field probe
  • #12500: Error of band selection
  • #12501: End frequency to high for used LISN driver
  • #12503: Error Detector CISPR Average
  • #12503: RadiMation automatic mode does not seem to measure all found peaks
  • #12505: Driver: Ametek NSG4060
  • #12508: Add reseller BluEmi
  • #12519: Check of the Yokogawa DL950 is always failing
  • #12525: RFB2000 not returning response on Pos:A and Pos:B
  • #12526: Teseq RFB2000 doesn't respond to queries
  • #12527: Teseq RFB2000 doesn't respond correctly on second test
  • #12532: Yokogawa DL950 is using SYST:ERR as an unknown command
  • #12535: Yokogawa Scopecorder DL950 returns Function not implemented for AD-Convertor
  • #12540: Yokogawa DL950 interprets channel number as the measurement value
  • #12547: Yokogawa DL950 Measuring Min and Max values
  • #12550: During burst crash
  • #12556: Add support for automatic HiSLIP
  • #12559: Tabor WW5061 initialisation error
  • #12560: Reflected power monitoring during forward power calibration
  • #12561: Measuring a value from the Yokogawa DL950
  • #12564: Tabor WW5061 Initialisation Error
  • #12570: Frankonia FC06.1 Antenna mast 1 polarization change
  • #12581: Termination settings are not forced on GPIB DeviceStream
  • #12590: Tabor WW5601 Error
  • #12590: Tabor WW5601 Set voltage does not match measured voltage
  • #12594: RadiMation freezes when configuring the RIGOL DSG815
  • #12599: device driver EM-Test NX7
  • #12608: Error during calibration (CI)
  • #12609: RPR2006C
  • #12611: Unable to set RBW in ESPI3 during Amplifier compression calibration
  • #12624: Preamplifier is not activated above 7 GHz on R&S ESI 26
  • #12650: Testlevel shown in linear interpolation.
  • #12668: Multiband of Absorbing clamp_not moving after 5meter.
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.3 .
