New version: RadiMation version 2022.3.6
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2022.3.5 version.
This version 2022.3.6 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2022.3.6 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2022.3.6 version (compared to the 2022.3.5 version):
  • #13365: Remove version from resource XML tag in wxWidgets XRC files to prevent warnings on start up
  • #13367: Error without description VISA: --> Timeout expired before operation completed
  • #13374: Changing the configuration directory does not result in restarting RadiMation
  • #13379: Possibility to ignore UNCAL error ESPI3
  • #13380: Text in textbox is not replaced in word report
  • #13381: When using the report generator code InsertFile an extra new line is added after the inserted content
  • #13382: WPF8 + SMP2 probe does time out when requesting field
  • #13405: Report generator attempted divide by zero
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2022.3 .
