Template file locatie "Graph to printer"
heutink
Post by heutink »
Within a conducted or radiated emission measurement (multiband) it is possible to "copy graph to clipboard" or "copy graph to printer".
For "copy graph to printer" a template *.doc ("printout" directory) will be used. Questions:
1. Is there a setting within Radimation to refer to another *.doc template.
2. So not, what are the standard templates for RE and CE multiband and can i make a copy of them and edit the content of these files.
Re: Template file locatie "Graph to printer"
Indeed when using the print button, underwater RadiMation will use a printout template to generate a report and send this to the printer.
For the end-user it is possible to modify the used printout template to your needs. However, there is no easy 'file selection' setting available within RadiMation itself.
Before modifying any these files we advise to make a backup first.
Then we need to find out which exact template is being used. This can be e.g. by adding a number to each available emission printout template and to press print in RadiMation.
This is to define which template is used when in your situation the print button is being pressed. The number should then be printed.
Now it is possible to adjust the printout template.
Does this answer your question?
The location of the 'Printout' templates can be found by checking the directory that is specified for the 'Printout Template Files' on the 'Directory' tab of the RadiMation configuration window.
Printout template directory selection on the RadiMation configuration window
The magnifier button can be used to very easily open the specified directory in the Windows Explorer.
The files in this directory all have a specific name, that determines which file is used, when something is printed from within RadiMation.
Some very often used printout template files are:
  • EUT.DOC: EUT overview
  • GLIMIT.DOC: Graph print of the limit line
  • RIMANUALMB.DOC: Radiated Immunity Multiband test results
  • GRIMANUALMB.DOC: Graph print of a Radiated Immunity Multiband test
  • RISUBST.DOC: Radiated Immunity Substitution test results
  • GRISUBST.DOC: Graph print of a Radiated Immunity Subsitution test
  • RIFIXPOW.DOC: Radiated Immunity Fixed power test results
  • GRIFIXPOW.DOC: Graph print of a Radiated Immunity Fixed power test
  • RIFIXFLD.DOC: Radiated Immunity Fixed Field test results
  • GRIFIXFLD.DOC: Graph print of a Radiated Immunity Fixed Field test
  • CIMANUALMB.DOC: Conducted Immunity Multiband test results
  • GCIMANUALMB.DOC: Graph print of a Conducted Immunity Multiband test
  • CISUBST.DOC: Conducted Immunity Substitution test results
  • GCISUBST.DOC: Graph print of a Conducted Immunity Subsitution test
  • CIFIXPOW.DOC: Conducted Immunity Fixed power test results
  • GCIFIXPOW.DOC: Graph print of a Conducted Immunity Fixed power test
  • CIFIXVOL.DOC: Conducted Immunity Fixed Voltage test results
  • GCIFIXVOL.DOC: Graph print of a Conducted Immunity Fixed Voltage test
  • REMANUALMB.DOC: Radiated Emission Multiband test results
  • GREMANUALMB.DOC: Graph print of a Radiated Emission Multiband test results
  • RECHAMB.DOC: Radiated Emission Anechoic Chamber test results
  • GRECHAMB.DOC: Graph print of a Radiated Emission Anechoic Chamber test results
  • REGTEM.DOC: Radiated Emission GTEM test results
  • GREGTEM.DOC: Graph print of a Radiated Emission GTEM test results
  • CEMANUALMB.DOC: Conducted Emission Multiband test results
  • GCEMANUALMB.DOC: Graph print of a Conducted Emission Multiband test results
  • CELISN.DOC: Conducted Emission LISN test results
  • GCELISN.DOC: Graph print of a Conducted Emission LISN test results
We are aware that this is not a complete list, of all the available files. If you want to know the correct filename for another printout, just ask us, and we will provide you with the correct filename.
