New version: RadiMation version 2017.1.7
We have released an updated minor version of RadiMation software, which includes several new device drivers and some small fixes for problems that have been detected since the release of the 2017.1.6 version.
The new 2017.1.7 release of RadiMation can now be downloaded from the DARE!! web-site. Image
We are currently not aware of known issues in this version.
The following issues are fixed in this 2017.1.7 version (compared to the 2017.1.6 version):
  • #6971: Driver: LeCroy WaveSurfer and Wave Runner oscilloscope series
  • #8538: Driver: CPI Amplifier J-series
  • #8541: Option to enable/disable frequency correction of PMM EP600-series
  • #8553: Support Mode 4 of the RadiPower
  • #8555: ErrorReport: "Collection was modified; enumeration operation may not execute. "
  • #8565: Driver: Steatite atennas
  • #8566: Driver: Flann Microwave antennas
  • #8569: Use Internal 10 MHz out for IFR 2023 Reference clock
  • #8582: Support the Preamplifier of the new TDEMI X
  • #8623: line coupling is only showing 1 line coupling in VDI TSF configuration
  • #8662: Object reference error while using minimum performance in a MB magnetic field closed loop method test
  • #8685: AD Channel colors are the same
  • #8689: Note field cannot be larger then 1000 characters.
If you have specific questions regarding on of the above items, please contact us at support@radimation.com
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2017.1.
