New version: RadiMation version 2022.1.3
roge
Post by roge »
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.3.8 version.
This version 2022.1.3 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2022.1.3 release of RadiMation can now be downloaded from the Raditeq website. Image
The following features/drivers are added to RadiMation 2022.1
  • #12127: Allow that the end-user can select another skin.
  • #4668: Allow to measure multiple detectors simultaneously during final measurement
  • #7849: Save TSF files even when warnings are present
  • #12534: Report generator improvements for speed and memory usage
  • #12744: Driver: Lumiloop 2.0+
  • #12688: Driver: Yokogawa DL750
  • #11501: Driver: R&S RTE1024 as powermeter
  • #12231: Driver: AFJ FFT3110.
  • #12661: Driver: RadiSwitch RSW1022V and RSW1024V.
  • #12529: Driver: SCHAFFNER EMI Receiver SCR 3502 (RS232).
The following issues are fixed in this 2022.1.3 version (compared to the 2021.3.8 version):
  • #9088: USB communication with RadiCentre is disturbed by Lumiloop TCP Server
  • #12020: Signal Generator Rohde&Schwarz SMCV100B
  • #12131: Update Raditeq dongle in chapter 2 of the manual
  • #12403: TSF RI limit line control, title of form is not shown, there is no OK button
  • #12538: BAND selection for driver of IFI T82-250.
  • #12557: Issues when starting tests using the EM-Test NX7
  • #12669: Multiband of Absorbing clamp can not move to 6m.
  • #12685: Primary GPIB address of 31 can be selected, while the maximum allowed primary GPIB address is 30
  • #12689: frmConfigTestLevelElectricalField uses wrong language resource id for the side button
  • #12698: LISN Network implementation
  • #12702: Stopping sequence
  • #12705: Configurable Antenna Tower - Commands for height missing
  • #12707: Report Generator does not run correct for EFT tests
  • #12714: Maturo FCU 3.0. Device driver not implemented
  • #12718: MIL-STD Peak discrimination is always NB when a RBW above 100 kHz is used
  • #12723: Start and stop frequency has changed during (de-)activation of the preamplifier
  • #12725: Test not closed.
  • #12729: Tektronix AFG3251C: Modulation frequency is not correctly set
  • #12733: Data out of range
  • #12734: Conducted Emission, data out of range
  • #12748: Frankonia AXL-200 raises error that device driver is unknown
  • #12750: Schloder CDG6000 powermeter device driver shows wxWidgets debug window
  • #12756: Initialisation of RadiSwitch takes a very long time when a Lumiloop is also connected
  • #12757: Initialisation of RadiPos takes a very long time when a Lumiloop is also connected
  • #12764: Extend the lumiloop LSProbe 2.0 driver to allow calibration of all 6 individual axis
  • #7849: Ability to save invalid TSF files and LLF files
  • #11321: TSF file of Burst/Surge test cannot be saved when no cable is selected yet
  • #11631: TSF cannot be saved if no protection key is present
  • #11861: ErrorReport: "*.TSF file change without dongle not possible!"
  • #11891: report generator text editor should not include RAW OADateTime values when generating reports
  • #12151: Possibility to save an incomplete configured TSF file to disk
  • #12158: RadiMation force closes when the process cannot acces the RadiLog file, because it is in use by another process.
  • #12263: VI instrument window graph control are moved of the visible area when resizing the form
  • #12359: Save *.TSF file without dongle not possible!
  • #12399: Error @ Restart last TSF
  • #12402: Limit lines are not shown when applying filter settings
  • #12404: Clean up invoke related code implemented on the RadiMation mainWindow
  • #12406: Add notification bar too the MB field probe test level, stating that multiple probes will be averaged
  • #12412: Device driver related UI components are not functioning as intented
  • #12446: SpinUpDownControl shows white text on white background.
  • #12464: Extend AD-Convertor driver for Tektronix TDS2000 series to allow USB connection.
  • #12536: Dark skin white border at Note and Address information.
  • #12539: issue 2022-03-30 AL1: frequency graph switch from log to lin after switching to Angle view.
  • #12544: Sequence overview menu item stays active when cancelled.
  • #12545: Connection problem
  • #12554: Ethernet Driver required for Agilent 33220A.
  • #12576: Error final peak measurement R&S ESPI3 with RadiMation 2021.3.5
  • #12588: When resizing the Pulse modulation configuration, the "Apply out of dwell time" is moved under the pulse gating frame
  • #12603: No export was possible of measurement T21 due to out of memory.
  • #12167: Validate LLF files at the start of test
  • #12622: Start and stop frequency on UFA calculation printout are always zero
  • #12623: Opening a unfinished PI data document will start a test without warning
  • #12636: The about window shows that the RadiMation 'Pro' license is used
  • #12637: Timeout while data transfer.
  • #12641: CI calibration error.
  • #12656: Logarithmic step frequency, starting from shows: -10000000000000 MHz
  • #12662: AM square wave modulation on Keysight N5171B generator.
  • #9256: Update the SX32W to the latest version released by Safenet.
  • #12125: The border of the non-maximized MDI child window is very narrow. Please enlarge it.
  • #12126: Show the title bar of a passive MDI child window in a different colour than the active MDI child window
  • #12127: Allow that end-user can select another skin.
  • #12245: If only a single fieldprobe is measured, it will be used as the average field, even if it is not selected to be included in the average calculation
  • #12278: RadiLog shows key-value pairs on the General tab instead of on the Input or Output tab
  • #12282: Automatically focus the sequence overview window when the last test of the sequence is finished
  • #12283: Option to select if the sequence window should remain open or close automatically.
  • #12337: Copy the RadiPower USB drivers from DRIVERS.EXE to a sub-directory to allow manual driver installation.
  • #12362: incorrect status info sequence.
  • #12392: Skin is not applied correctly when switching from the windows default to another skin.
  • #12417: error while applying new skin.
  • #12441: The corners of the buttons on the VI windows have white pixels in a dark skin.
  • #12442: Unexpected borders are shown around buttons on some skins.
  • #12444: Forms having a fixed light colour even using darker skins
  • #12534: AW: Export from Version 2021.3.5 => Out of Memory.
  • #12628: Control of an EUT controller is not allowed in the 'Essential' license type
  • #12629: Control of a positioner is not allowed in the 'Essential' license type
  • #12631: The main window title bar includes 'RadiMation Essential' when the Essential license is used
  • #12643: Voltage dips test
  • #12663: Rohde & Schwarz BBA150 connection error
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2022.1 .
