This version 2026.1.5 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation on, for example, a separate PC or laptop with your setup and measurement equipment, before you are going to use it for daily operation.
The new 2026.1.5 release of RadiMation can now be downloaded from the Raditeq website.
We always advise to thoroughly test each new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is also a requirement for ISO 17025 accredited test laboratories. To enable customers to validate new software versions before implementing them, we have made it possible to install multiple versions of RadiMation side-by-side on a single PC. It is, of course, also possible to perform this validation on a separate PC or laptop.
Fixed issues and improvements
The following issues are fixed or improved in this 2026.1.5 version (compared to the 2026.1.4 version):
- #16053: Ensure that each Graph tab is displayed only once
- #16510: Use a 100 kS/s sample rate for the RadiPower RPR2006F when a 1 kHz VBW is selected
- #16529: Fix slow typing in the test result notes of multiband EFT, Surge, and VDI test configurations
- #16694: Add device driver for Raditeq RPR2006F
- #16976: Add device drivers for Frankonia CORE-6
- #17469: Prevent continuous scanning when retrieving measured values from R&S ESU receivers, which could lead to incorrect data in certain cases
- #17500: Show an error when a correction file created with a newer version is opened in an older version
- #17528: Ensure the N9038 driver stops running measurements before selecting the RF port
- #17537: Prevent continuous scanning when retrieving measured values from R&S ESU receivers, which could lead to incorrect data in certain cases
- #17550: Add support for Maury MPA series amplifiers
- #17554: Fix debug assertion warnings when starting RadiMation
- #17564: Preserve the units configuration for Radiated Immunity after restarting the application
- #17567: Remember the last-used TSF directory for each test type
- #17615: Fix an issue that could cause report generation to fail after reopening a saved document when device settings were stored in an unnamed INI section
The complete list of release notes can be found on: RadiMation 2026.1 release notes.
