Fixed Power Multiband in 2012.1.17
Rosu
Post by Rosu »
it seems that i installed the new version succesfully. Conducted immunity multiband seems to not work properly.
1) By changing of the frequency band @100MHz due to amplifier end of frequency range. Radimation is not deinitialising the test equipment and is giving the error as in the document attached. Quiting the error radimation changes in manual mode. By choosing the next band its working ok.
2) Furthermore trying to display a graph in the frequency mode of the display isn't working properly: I had to change in the table mode, implement the graphs I need to see and after that to change in the frequency mode. Than seems to be OK, but: if i try to implement a further Graph in frequency mode Radimation gives the error in the attached document and closes.
Marius
fehler_AR151A100_AR150W1000.docx
(844.03 KiB) Downloaded 915 times
Re: Fixed Power Multiband in 2012.1.17
Hello Marius,
Thanks for your report. I will investigate it...
Your first issue is not yet verified. However, it is saved in our database: #4248: Error start and end frequency. You might provide more detailed information about the settings you use when this issue occurs? It seems that issue 2 is indeed present and can be reproduced. It's also saved as a defect in our database: #4247: Display graph isn't working properly, and we will continue the investigation.
Rosu
Post by Rosu »
i found a wrong setup in the tsf. May be this is the reason for the behaviour. I saw that a band 100MHz-100MHz as frequency band in the multiband test is included. May be you can highlight a popup so that the user cannot include some bands like this. I will check asap if this is the reason.
Kind regards
Marius
Rosu
Post by Rosu »
please find attached some additional screen shots for the test and the tsf. The additional band 100Mhz-100Mhz was not the reason for the behaviour.
Kind regards,
Marius
BCI, 1-400MHz, CW, CAT3 Level1, 750mm.TSF
TSF file
(10.38 KiB) Downloaded 969 times
Equipment and Band mask.docx
Screenshots
(525.03 KiB) Downloaded 929 times
Hello Marius,
I checked the issue: #4247: Display graph isn't working properly, and we will continue the investigation.
Those problems are now fixed (in version 2012.1.18). That version is not available yet, but in the next version of RadiMation the graphs are working correctly again.
Hello marius,
In the past we discussed the issue: #4247: Display graph isn't working properly, and we will continue the investigation.
That issue should have been fixed in version 2013.1.6 which is now available.
