RadiMation 5.8.33 Manual
The images do not appear in the manual which came with the RadiMation 5.8.33.
Re: RadiMation 5.8.33 Manual
I checked it, and you are indeed correct.
The PDF that is disributed with the RadiMation version 5.8.33 software, doesn't include the pictures.
The PDF is automatically generated from the RadiWiki site http://wiki.radimation.com.
The latests manual is available at: http://wiki.radimation.com/wiki/index.php/Manual That version of the manual is showing the pictures.
We expect that during the automatic generation of the manual something has been broken. (because we also changed the behaviour of the RadiWiki site).
We will continue to investigate the problem.
In the meantime I would like to suggest to use the manual at: http://wiki.radimation.nl/wiki/index.php/Manual
labemcteseo
Hi all,
same problem with version 5.8.34
Could please check and fix the issue?
Thanks very much!
Claudio
Thanks very much!
Claudio
The generation of the manual, indeed has some problems.
This was caused by the changes, that the RadiWiki site is now available for everyone.
I already made the improvements to correctly include the pictures in the manual again.
The next software release the manual will be containing the pictures again.
I also found some other problems, which I'm still investigating (and hoping to fix them).
