New version: RadiMation version 2024.1.11
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2024.1.10 version.
This version 2024.1.11 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2024.1.11 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2024.1.11 version (compared to the 2024.1.x version):
  • #14790: Driver: Frankonia FBM1-4 boresight for FC06.1
  • #14954: The problem of temporary files not inserted in Microsoft Excel reports is resolved, also now xlsm files can be included
  • #15409: Driver: Teseq CBA 1G-300D
  • #15411: Driver: Milmega AS0860B-50/50
  • #15423: Driver: Milmega AS0102-65
  • #15713: Image files are correctly inserted in Microsoft Excel reports
  • #15745: SMCV100B Error activating lock screen
  • #15751: Surge Testing with NX7 and DCD 5-A sr-8-4.1 combination
  • #15792: Frankonia RSU option to disable the interlock check
  • #15774: Milmega AS0860B now uses the AC-001 command set for GPIB
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2024.1.
