New version: RadiMation version 2025.1.3 (BETA)
We have released an BETA version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2024.2.x version.
This version 2025.1.3 (BETA) is at this moment only provided as a BETA release, as it has NOT YET been fully validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.1.3 (BETA) release of RadiMation can now be downloaded from the Raditeq website. Image
  • This is a BETA release that has not yet been fully validated.
  • #9118: Ambient suppression in Multiband Emission GTEM causes that the GTEM correlation is not performed.
The following issues are fixed in this 2025.1.3 version (compared to the 2024.2.x version):
  • #7078: Dialogs are now always shown on the same screen where RadiMation is open
  • #8742: Band control shows frequency markers for multiband test configuration
  • #9490: Double clicking on the name of a graph element in the legend of a multiband graph shows the graph customization for the element
  • #10299: A minimum RBW of 1 Hz can now be selected
  • #10949: Report generator file and directory select boxes now accept drag and drop
  • #12237: The popup with band-related operations is now also shown when right-clicking on an empty area
  • #12906: Newly added rows to the correction file will contain the next logical frequency
  • #13086: The reveal buttons (with a magnifying glass symbol) in the list of correction files for a device driver now correctly show as enabled when a file is selected.
  • #13774: Correction files can be dragged to the correction file list of the device driver settings
  • #13774: Directories can be dragged to the Directory configuration within the configuration
  • #14091: Allow clicking graph line names to open the graph line configuration window
  • #15157: Include a check during startup that the the decimal separator and thousands separator are different
  • #15510: Update to new DevEpress 24.2.3
  • #15610: Files can be dragged to the Template and Report configurations for EUTs (under the Reports tab).
  • #15635: It is now possible to highlight a graph element by clicking its name in the legend. This emphasises the element by drawing it thicker and drawing other elements with increased transparency. Each of these behaviours can be individually controlled in the advanced settings.
  • #15678: #15677: Improvements related to graph element selection
  • #15680: #15677: Improvements related to graph line highlighting
  • #15683: Fix crash when switching to table tab while filter dropdown is open
  • #15698: Fix bugs related to code conversion
  • #15725: A minimum RBW of 1 Hz can now be selected
  • #15734: Improvements related to text conversion of double values
  • #15749: Improvements to code base
  • #15752: Y axes can now be manually scaled, either by dragging the axis or more precisely configuring it through a right click menu .
  • #15770: It is no longer possible to drag markers beyond the visual bounds of the graph
  • #15780: The graph division setting is now correctly limited to the range of [4,20], preventing possible crashes when it is too low.
  • #15873: Climate chamber test graphs now scale correctly, and the same way while the test is running and after the test
  • #15874: Climate chamber test graphs are now laid out the same way during and after the test, and can be toggled to have more screen space for one of the graphs.
  • #15837: Fix index out of bounds error
  • #15896: Clicking a line in the legend to highlight it also highlights the corresponding axis
  • #15908: The 'full span' button no longer looks enabled when it isn't on certain screens.
  • #15940: Paths can now be copied from file selectors through a right-click context menu
  • #15941: Improvements related to checking the software key
  • #15999: Fix DevExpress object null reference error when generating reports
  • #16006: All whitespace characters are accepted in report generator codes
  • #16007: Removed projects darevw and daredbg
  • #16026: Driver: Power meter driver for R&S ESPC
  • #16046: Fix: Multiple bands set at the same single frequency is only shown as 1 band in the band selection control
  • #16092: Fix: Cursor no longer jumps to start of text on Enter in Pause test configuration.
  • #16111: Improvements relation the correction file UI
  • #16122: When a correction file or limitline file is closed, the corresponding external graphs are also closed.
  • #16138: A single band with identical start and stop frequency is now centered and rendered with 50% width.
  • #16145: The example graph in the configuration form uses the configured vertical divisions setting
  • #16165: The column order in correction file no longer changes when a column is removed
  • #16168: Remove the initial row from the correction file when data is pasted
  • #16176: The position of the external RadiMation windows is saved and restored the next time they are opened
  • #16183: Include required DLL in setup
  • #16194: Always display newly opened windows fully within the visible area.
  • #16206: Fix issue where the VDI did not start because of a missing antenna in the test-site
  • #16207: Fix an issue where a antenna was required during LISN tests
  • #16208: Fix an issue where the location type setting of a TSF file unexpectedly changed
  • #16210: Fix collection modified error
  • #16208: Fix saving of the antenna polaristion in TSF files
  • #16213: VDI tests now start correctly
  • #16217: Improvements related to localization of UI controls
  • #16220: Fix antenna required during VDI tests
  • #16233: Fix issue where measurement data was stored in an incorrect graphline
  • #16247: The list of added devices in the device drivers configuration is displayed when the configuration is opened.
  • #16248: UTF-8 characters are now connectly shown for devices
  • #16253: Correction file UI improvements
  • #16255: The list of devices and test sites is now refreshed immediately when the button in the navigation is pressed
  • #16256: Parts of languages (other than English) are now shown again in English
  • #16257: language file improvements
  • #16259: Improvements related to releasing language file updates
  • #16261: Syntax errors in the language conversion files are resolved
  • #16263: Fix field strenght column can be removed from the list of correction columns
  • #16279: Fix loading on controls on singleband tests after localization
  • #16284: Receiver settings in singleband emission settings are correctly shown
  • #16288: Fix loading on controls on singleband tests after localization
  • #16296: Selected power calibration method is shown again in the test level configuration
  • #16306: General improvements
  • #16304: Unit of signal power and amount of samples are shown again Attenuation System calibration
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2025.1.
