New version: RadiMation version 2025.1.6
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.1.5 version.
This version 2025.1.6 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.1.6 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2025.1.6 version (compared to the 2025.1.x version):
  • #15367: Driver Lumiloop LSPM
  • #16523: Actual test frequency is communicated to the RSS2018S
  • #16598: Update InnoSetup to 6.7.0
  • #16598: Use HTTPS connection to download the latest DRIVERS.EXE during setup
  • #16630: Clear input buffers of the Milmega amplifier driver
  • #16640: Fix tests in a running sequence appearing in the wrong order
  • #16656: Start frequencies are set to the expected value when changing TSF settings with multiple bands selected
  • #16667: Fixes a RadiMation crash when creating a report with harmonics data
  • #16691: Fix equipment database configuration window not being shown
  • #16693: Provide clarrification of RPR3008W settings
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2025.1.
