New version: RadiMation version 2025.2.6
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.1.x version.
This version 2025.2.6 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.2.6 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2025.2.6 version (compared to the 2025.1.x version):
  • #2695: Correction files can now be viewed from the multiband immunity test configuration
  • #3404: The automatically generated PDF manual is improved
  • #5472: Frequency lists can now be inspected in the multiband radiated immunity setup form
  • #6676: Add the possibility to add auxiliary equipment to the test site
  • #10668: Page breaks in the first part of the PDF of the manual are corrected
  • #12869: When displaying a correction file from a test, it now shows a graph as well as a table
  • #12945: Show a horizontal scrollbar when the columns of the correction file do not fit
  • #13289: The password form can no longer be minimized or maximized
  • #13339: Use gRPC to control RadiLog from RadiMation
  • #13400: Table of contents in the PDF manual shows all chapter levels again
  • #14540: The About screen now correctly appears on the secondary monitor when RadiMation is running there.
  • #14553: Allow quickly pressing buttons that move elements of the list
  • #14557: Auto Detection: "Add more" button is now focused by default when more devices are found
  • #14563: Quick clicks on buttons to move tests in the sequence are now accepted
  • #15234: Allow multiple selection of cables in the EUT form
  • #15315: Possibility to show one or more graphlines in a separate graph window in a multiband test
  • #15701: Use the copyright of the correct year in the user manual
  • #15788: When editing a correction file, multiselecting rows is now possible, allowing for the quick removal of multiple rows or the copying of only a portion of the correction data
  • #15864: Quick clicks on buttons to move tests in the sequence are now accepted
  • #15870: Fixes related to positioning of the cursor the cursor
  • #16063: Improvements related to loading advanced settings
  • #16112: Choose the text color for the pause test based on the current skin
  • #16160: In the multiband test configuration, scale the band rectangles to ensure all bands are visible
  • #16172: When pasting data into a correction file, the optimal frequency unit will be used automatically if a unit is not included
  • #16193: Add a hashing function to FrequencyMHz
  • #16204: Graph lines highlighted by clicking them in the legend are now moved to the front when possible
  • #16272: Allow RadiSense user correction retrieval via advanced configuration -> "User correction", and automatic retrieval during test start using RadiSense EUT controller
  • #16275: Pasting correction data with more columns than are configured for the correction file will no longer cause an error
  • #16281: Frequencies within RadiMation and Drivers are now compared and rounded in the same manner
  • #16364: Allow insertion of GPAPH or TABLE of .COR/.LLF attachments into the report
  • #16370: Allow renaming of EUT attachment
  • #16371: Allow the use of wildcards * and ? in the filename for the ATTACHMENT keyword in the report generator
  • #16372: Fixed magnifier button not being visible for some file/directory selectors
  • #16407: Refresh the file size of the attachment in the table after editing its contents
  • #16414: Handle quick button clicks appropriately
  • #16434: Spaces in attachment filenames are now taken into account when using the ATTACHMENT report generator keyword
  • #16435: Break references by using deep copy when duplicating tests in sequence
  • #16437: The filenames of the EUT attachments are now preserved when the attachment is edited
  • #16438: Attachments are now exported to disk only when requested
  • #16443: In the multiband test configuration, immediately display frequency labels for all bands after opening the window
  • #16449: Copying a correction table no longer adds a trailing tab (\t) after the values in the last column.
  • #16454: Adjusted rounding for decimal numbers to max 15 decimals
  • #16455: Fixed potential crash after RadiMation is running for 25 days
  • #16492: Support .TIF and .EMF image formats in Excel report generator
  • #16521: Do not translate objects in ComboBoxEdit
  • #16524: Display an error when unable to connect to RadiLog within 10 seconds
  • #16530: No 'No description available' device drivers are created anymore in the testsite when configuring a test.
  • #16532: 'coupling NX5 bs-3-480-32' is not shown twice anymore in the EMTest NX5 Surge device driver
  • #9260: HTTPS will be used to upload the errorlog
  • #15478: Several improvements in the PDF version of the manual
  • #16321: Fix unhandled exception when removing limit lines from a multiband RE test results
  • #16334: Limit lines shown in grids can be viewed by double clicking
  • #16390: Improvements related to parsing of file contents
  • #16487: String comparison improvements
  • #16509: Textual improvements related to auxilary equipment
  • 16515: Error report is now using port 443
  • #16539: Fix object null reference errors when closing EUT address information for client
  • #16542: Include the DLLs required by gRPC in the setup
  • #16079: Fix previous selected calibration file is cleared when selecting a new file is cancelled
  • #16534: Clean up project
  • #16540: New reseller Beijing Xinhui Electronics Co
  • #16546: Fix Directories in Configuration form sometimes appearing empty
  • #16562: Fix button "Add [Device Type]..." not appearing in Devices bar
  • #16564: TDEMI: Fix CAVG is not activated during pre-scan if this is not configured
  • #16579: Add margin to fully display the name of the test site in the selection drop-down
  • #16598: Update InnoSetup to 6.7.0
  • #16598: Use HTTPS connection to download the latest DRIVERS.EXE during setup
  • #16620: Make links in "Check updates" point to the corresponding RadiWiki page
  • #16620: Create all existing XML versions that need to be updated.
  • #16633: Fix report generation using read only protected template files
  • #16640: Fix tests in a running sequence appearing in the wrong order
  • #12715: Allow selection of 115200 baud rate for RadiCentre multislot, connected via USB with communication set to RS-232
  • #16323: Show correct sequence overview window icon.
  • #16359: Driver: Prana SX250DC 100
  • #16503: Use double-precision floating-point numbers for power measurements
  • #16520: RTO Allow enabling of auto-scaling in the advanced settings
  • #16559: Add advanced setting to select between smooth and discrete scan type if allowed
  • #16625: If requests to Netatmo are rate-limited, retries with a backoff timer are used
  • #16635: Allow StorableMemberVariable<T> to be inserted into a stream
  • #16641: Add application note on user preset configurations with R&S analyzer type devices
  • #16654: Allow selection of 115200 baud rate for RadiSense EUT controller when connected via USB to RadiCentre multislot
  • #16654: Now baud rate 115200 can be selected for RadiCentre multislot when communication is set to RS232
  • #16655: Don't write a tsfdir.ini in the root of the TSF directory
  • #16674 Update default settings for Tektronix SignalVu driver.
  • #3041: A new version of the TSF directory structure has been implemented that can be modified on disk.
  • #15766: Simplify emtest NX-Series coupling line selection
  • #15811: Improve DCD coupling line selection
  • #15835: Graph default settings are now correctly disabled when the engineer lacks permissions.
  • #16033: Show communication and receiver tab of the R&S ESPC power meter
  • #16519: RTO Allow selection of High Impedance DC coupling in the advanced settings
  • #16551: Testing advanced coupling line configuration with NX-series and DCD 5-A b-8-4
  • #16617: Add Werlatone C10870
  • #16646: Ethernet device stream will return correct error description when not all bytes are read from the stream
  • #16649: Add device driver Prana MT 250 DC
  • #16650: Add device driver Agilent Technologies E4438C
  • #16662: Use 1 milliHz accuracy for frequency of multiaxis field measurements
  • #16665: All engineers are now able to change their own password
  • #16666: Engineers with 'Engineer' permission no longer need the old password to change an engineer's password
  • #16668: NX series add parallel coupling options for the burst DCD coupling
  • #16691: Fix equipment database configuration window not being shown
  • #16740: Fix issue where environmental data from Netatmo did not appear in test result information items
  • #16752: Fix crash caused by sorting a very large list
  • #16769: Add RF SPIN antenna device drivers
  • #2715: TSFs can now be dragged in the TSF selection screen or moved on disk
  • #5315: Add ability to drag and drop TSF files in the SelectTSF dialog
  • #9562: TSF files can now be moved, renamed and copied on disk and are named clearly with their description as a filename
  • #16741: Add validation for information item names to prevent the possibility of adding multiple items with the same name
  • #16776: Driver: Bonn BLWA 0830-50D dual band amplifier
  • #16827: RadiSense EUT Controller: use %temp% directory as the location for the temporary correction file
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2025.2.
