New version: RadiMation version 2025.1.9
Posted: 12 May 2026, 10:45
by roge
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.1.8 version.
This version 2025.1.9 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.1.9 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2025.1.9 version (compared to the 2025.1.8 version):
  • #16611: Rigol DSA series now maintains the sweep time when zooming in.
  • #16631: Fix hand cursor not being shown when hovering over graph data points
  • #16653: Fix frequency graphs and table indexed on time are now visible in the virtual instrument window test
  • #16888: Allow the limit line in the table export of the graphline to have no data at points that do not fall under that limit line
  • #16889: Limit lines no longer create new index points in the graph line table export. Only existing measurement points are used for the index
  • #16907: Fix inability to insert a row at the beginning of the limit line table
  • #16914: Fix calibration files do not calculate results if the frequency is not available
  • #16952: Fix graph customisations to be saved in the test result
  • #16971: Fix calibration testlevel does not calculate results if the frequency is not available
  • #16973: Fix Angle plots can be inserted again using the report generator
  • #16978: Fix "Max Peak" sometimes appearing alongside "Horizontal/Vertical/Both Max Peak" during continuous peak measurement
  • #17007: Angle plots inserted by the report generator are not depending on the peak selected state
  • #16951: Update mouse pointer shape to "hovered" when hovering over a graph datapoint
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2025.1.
