New version: RadiMation version 2025.1.8
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.1.7 version.
This version 2025.1.8 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.1.8 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2025.1.8 version (compared to the 2025.1.x version):
  • #14334: BLN modulation is now available in RadiMation
  • #14335: AWGN modulation is now available in RadiMation
  • #14933: Driver: Audivo Pecos 8.2
  • #15120: AWGN and BLN modulation is now possible with R&S SMCV100B Generators
  • #15322: PECOS 8 device driver
  • #16350: Save correction is shown when creating a new correction file.
  • #16664: Drivers: R&S FSH-8
  • #16766: NX-series now selects correct IEC phase mode command based on the connected coupling device
  • #16773: SMF100A carrier level can be set to -30 dBm
  • #16786: Fix NX series Surge generator coupling mode selection
  • #16794: NX -Series surge now raises errors when invalid resistance and capacitance values are selected for a DCD automated coupler
  • #16795: NX series allow testing power and data line coupling device testing in the same TSF
  • #16806: Axos 5 now sends te correct command to switch the SHV output for EFT.
  • #16814: Axos 5 now sends te correct command to switch the SHV output for Surge.
  • #16820: NX series SURGE: Add coupling NX 5 and 7 bsp-1-300-16
  • #16844: Stepsize of reverberation chamber calibration can now be configured
  • #16846: Reverberation test windows now show correct title
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2025.1.
