New version: RadiMation version 2025.1.7
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.1.6 version.
This version 2025.1.7 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.1.7 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2025.1.7 version (compared to the 2025.1.x version):
  • #16503: Use double-precision floating-point numbers for power measurements
  • #16699: Fixes file not found message when the device driver database is not configured
  • #16708: Implemented input disconnect for the R&S ESW during deinit phase
  • #16717: Fixes the report generator code ||Configuration|CURRENTENGINEER||
  • #16728: Add reseller x.test
  • #16752: Fix crash caused by sorting a very large list
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2025.1.
