New version: RadiMation version 2025.2.7
Posted: 12 May 2026, 11:33
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2025.2.6 version.
This version 2025.2.7 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2025.2.7 release of RadiMation can now be downloaded from the Raditeq website.
The following issues are fixed in this 2025.2.7 version (compared to the 2025.2.6 version):
The complete list of release notes can be found on: http://wiki.dare.nl/wiki/index.php/Release_Notes_2025.2.
- #16631: Fix hand cursor not being shown when hovering over graph data points
- #16784: Siglent SSA5085 clear error queue during init phase
- #16887: Tektronix MDO 4104C Prevent roll mode option
- #16888: Allow the limit line in the table export of the graphline to have no data at points that do not fall under that limit line
- #16889: Limit lines no longer create new index points in the graph line table export. Only existing measurement points are used for the index
- #16892: Optimise memory usage when creating a report with many graph lines containing numerous traces
- #16897: Maturo FCU3 check if the turn table or antenna tower is enabled
- #16907: Fix inability to insert a row at the beginning of the limit line table
- #16878: Add button is enabled for product standard
- #16951: Fix mouse cursor is not shown as expected when selecting peaks
- #16952: Fix graph customisations to be saved in the test result
- #16973: Fix angle plots for all measured peaks can be inserted in reports.
- #16978: Fix "Max Peak" sometimes appearing alongside "Horizontal/Vertical/Both Max Peak" during continuous peak measurement
- #16979: "Peaks to maximum" no longer changes the order of the peaks
- #16995: Fix graph customisations to be saved in the test result
- #17008: Stop frequency of a band very close to another band is tested twice
- #17009: Amplifier research FM-5004 added visa communication stream
- #17010: E4438C supports internal AM modulation
- #16951: Update mouse pointer shape to "hovered" when hovering over a graph datapoint
