New version: RadiMation version 2026.2.3
We have released an updated version of the RadiMation software which includes several improvements and fixes for problems that have been detected since the release of the 2026.1.x versions.
This version 2026.2.3 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation using for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
RadiMation 2026.2.3 is available from the Raditeq website.
What's new in RadiMation 2026.2
  • Select the test modules available at each test site.
  • Customise, scale, and zoom graphs in the correction editor.
  • See a progress bar while a pause test is running.
  • Use EUT controller events in pulsed immunity EFT and Surge tests.
  • Configure pulse train modulation with corrected minimum and maximum values.
  • RadiMation now runs on Microsoft .NET 8.
Fixed issues and improvements
The following changes are included in 2026.2.3:
  • #16529: Fix slow typing when editing test result notes in multiband EFT, Surge, and VDI test configurations.
  • #17586: Display tabs in the configured order in multiband immunity tests.
  • #17606: Make the driver's download option clearer and show the bundled driver version in the installer.
  • #17615: Fix a report generation failure that could occur after reopening a saved document with device settings in an unnamed INI section.
  • #15634: Speed up drivers installation by shipping language files as an archive
  • #16053: Ensure that each Graph tab is displayed only once
  • #16690: Improve TESEQ NSG4000 to use frequencies more accurately
  • #16817: Improve InterpretFrequency to correctly store the parsed frequencies
  • #17363: Format EnumClass with an empty format specifier instead of "%s"
  • #17500: Show an error when a new correction file is opened with an older version
  • #17520: Device driver: NRP-Zxx power meter connected to an SMBV100B
  • #17530: Update the R&S ESAI spectrum analyser to support the VISA communication method
  • #17546: Improve logging of the metadata for the dynamically loaded DLLs
  • #17564: The units configuration for Radiated Immunity is no longer forgotten after restarting the application.
  • #17567: Last used TSF directory is now remembered for each test type.
  • #17575: Fix an issue where the duration of a RadiLog log entry is calculated incorrectly
  • #17588: Prevent repeated software protection checks during each screen update
  • #17591: RadiSense 2010 driver does not send 'CAL' commands for firmware v3 and higher
  • #17592: The EUT general information retriever is not interpreting the response as a possible error anymore
  • #7002: Remove the "initial" row when data is pasted into the correction file
  • #9006: Fix incorrect mouse cursor coordinates displayed when using the Height Graph
  • #9934: Graph text elements now maintain a consistent font size regardless of the graph dimensions.
  • #10658: The pause test no longer displays the message to save its data when closed
  • #10904: Show progress bar while the pause test is running
  • #14014: Fix the value and amplitude being swapped on the height graph
  • #14741: Add a signal generator driver for the R&S FPL10xx with a tracking generator (option B9)
  • #15868: Show progress bar while the pause test is running
  • #15930: Upgrade to Microsoft .NET 8.0
  • #16197: Add a signal generator driver for the R&S FPL10xx with a tracking generator (option B9)
  • #16363: X, Y, and Z corrections now share the same axis on the correction graph
  • #16677: Administrator's permissions cannot be removed anymore
  • #16706: Add device drivers for the R&S FPL1014 and FPL1044
  • #16875: Do not allow multiple EUT cables to have the same description
  • #16964: Administrator's permissions cannot be removed anymore
  • #16966: Improve the speed and usability of the Excel equipment database
  • #17114: Improve busy status, reduce UI flickering while commands are executed
  • #17155: Prevent tests from executing in parallel
  • #17227: Add support for pulsed immunity EFT and Surge EUT controller events
  • #17385: Improve the correction edit graph to use customisations, scaling, zooming, and other standard graph functions
  • #17391: Add LAST, FIRST, NEWEST, OLDEST selectors for ATTACHMENT report generator keyword
  • #17416: Add device driver for the R&S FPL1026
  • #17496: Always update the file path selector when it is loaded
  • #17497: Correct the minimum and maximum values of the pulse train modulation line
  • #17506: The font sizes in the angle, frequency, and height graphs are now consistent.
  • #17507: Fix the value and amplitude being swapped on the height graph
  • #17526: Use ANSI encoding to read device driver INI files without a BOM
  • #17545: Ship the newest available .NET runtime in the RadiMation installer
If you have questions about this release, please contact us at radimation-support@raditeq.com.
For the complete list of changes, see the RadiMation 2026.2 release notes.
