Correction file for differential voltage probe
Performing a "Conducted Immunity > Multiband > voltage closed loop" test. Using a diff. voltage probe (attn. factor of 10) on the multimeter input. Where can i define the correction factor of 10 for this probe in the "test site". As work around, i define the test level a factor of 10 lower. However, i want to use the correct test level and define a correction factor for diff. voltage probe or for the input of the multimeter.
Re: Correction file for differential voltage probe
Currently there is no option available to attach correction files to a multi-meter.
There is also no option to add a correction through a cable, as there is no such cable defined for multi-meter devices.
by your request however, we can make a new ticket describing your mentioned functionality as a wish.
Doing so it will be taken in consideration for future improvements of the software.
