New Version: RadiMation version 2021.2.3
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.1.9 version.
This version 2021.2.3 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.2.3 release of RadiMation can now be downloaded from the Raditeq web-site. Image
The following features are added to RadiMation 2021.2
  • #2273: Multiband Conducted emission absorbing clamp.
  • #5579: Stopping a sequence is almost impossible.
The following issues are fixed in this 2021.2.3 version (compared to the 2020.1.9 version):
  • #9170: Some properties set in the polarGraph init function get reset when the graph is actually drawn.
  • #11892: Before/After actions Pauze window does not close it self, or by clicking the OK button.
  • #11851: Minimum absorbing clamp distance is 1 mm. This should be changed to 0mm.
  • #11854: Final measurement stops after first final measurement if distance graph is selected.
  • #11855: If the default graph configuration is set to logarithmic, a strange x-axis is shown for distance graph
  • #11856: If distance unit is set to cm, the frequency too high errors are generated in the distance graph
  • #11857: The unit configuration of the distance is not used in the graph x-axis
  • #11858: Limit line in the distance graph is shown as a curved line. This should be a straight line in the distance graph.
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.2 .
