New version: RadiMation Version 2021.1.11
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.1.10 version.
This version 2021.1.11 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.1.11 release of RadiMation can now be downloaded from the Raditeq web-site. Image
The following issues are fixed in this 2021.1.11 version (compared to the 2021.1.10 version):
  • #11501: Driver: R&S RTE1024 as powermeter
  • #11503: Driver: BLMA 0118-1A.
  • #11506: Driver: Driver: IFI T82-250
  • #11658: ErrorReport: "Teseq NSG3040: Device returned Error code: 13"
  • #11801: RTO2024 - Leveling time and Voltage measurement error.
  • #11839: Device driver for Rohde&Schwarz FSV3000 Spectrum Analyzer
  • #11883: Driver: AR125S1G6
  • #11886: The device driver system is currently not usable.
  • #11903: RadiMation stops on initialisation
  • #11904: IFR2025 High power option.
  • #11906: Driver: RS FSVA 3044.
  • #11916: Device driver: Amplifier BBA150BC500
  • #11917: Device driver: AmplifierBBA150D200
  • #11918: Device driver: Amplifier BBA150E100
  • #11921: Prana N-MT 1650 DC
  • #11923: Driver: TESEQ KEMA801A
  • #11925: Device driver LISN TESEQ ISN-T8
  • #11926: Device driver LISN EMTEST DCD-sr
  • #11927: Device driver LISN EMTEST DCD-st
  • #11934: Device driver: Antenna SAS-521F-7
  • #11935: Driver: Modulation source Tektronix AFG3102
  • #11942: Driver: Antenna Schwarzbeck VULB9164
  • #11948: ErrorReport: "Fehlermeldung bei der Multibandmessung (Nachmessung)"
  • #11949: VI powermeter envelope tracing mode issues in new version
  • #11956: RE: Switch-Matrix TESEQ RFB2000 - Inbetriebnahme in RadiMation
  • #11960: ErrorReport: "CE met Peak en AV trace" measuring time changed from 200 ms to 10 ms
  • #11963: Radimation/Lumiloop error during field probe mode switch
  • #11968: R&S NRP18A time-out when using high filter count.
  • #11980: ErrorReport: "layout of emission plots"
  • #11983: Driver: R&S FSVA 3044 SA
  • #11984: RadiPower advanced option to configure the used VBW during remote measurement
  • #11985: Test level input should disable tolerance
  • #11997: R&S NRP-Z91 Powermeter confused.
  • #12000: amplifier linearity check - forward power step issue
  • #12003: ErrorReport: "EFT test sequnce does not run"
  • #12005:Device driver for EM-Test NX7 with DCD Burst coupling network
  • #12006: RadiMation Help button redirects to Dare.eu instead of Raditeq.com
  • #12018: ErrorReport: "Rohde & Schwarz RTO2024 (CH2): Specific System Error: -222,"Data out of range;CALC:MATH2:FFT:STAR 70698577.88"".
  • #12036: Report Generator Harmonics & compression not inserted
  • #12041: Build RadiMation 2021.1.10
  • #12048: Data is not updated in Power meter virtual instruments window.
  • #12057: ErrorReport: "FM modulation multiband could not be set".
  • #11969: Keysight U200A/U2004A time-out when using high filter count.
  • #11995: Radimation freezes when the operation, temperature and humidity controls are opened for a few minutes
  • #12007: Driver: Tabor Electronics WW5061 signal generator
  • #12027: Singleband Live Emission mode raises error in ESR26/ESW.
  • #12038: ErrorReport: "error with pulse immunity , sequence stops suddenly".
  • #12049: Driver: LISN1-D
  • #12051: Don't limit frequency to 9.9 GHz in field probe.
  • #12052: Driver: LeCroy WaveSurfer as power meter.
  • #12055: Driver: RPR4000.
  • #12068: Build RadiMation 2021.1.11
  • #12070: Loading externally generated limit lines.
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.1
