New version: RadiMation Version 2021.3.7
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2021.3.3 version.
This version 2021.3.7 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2021.3.7 release of RadiMation can now be downloaded from the Raditeq web-site. Image
The following features are added to RadiMation 2021.3
  • The number of vertical divisions of a graph can be configured
  • Disabling continuous measure is not confusing anymore
  • Expected *IDN? of the majority of device drivers can be modified
The following issues are fixed in this 2021.3.7 version (compared to the 2021.3.5 version):
  • #10321: Driver: ETS-Lindgren: VisionTRX
  • #10322: Errorcodes for VisionTRX
  • #10323: VisionTRx optimization GetChannelValue function.
  • #11641: Alarm in channel in VisionTRX is not shown in RadiMation
  • #12353: Error modulation ON in conducted immunity
  • #12425: Error: Could not set value in device, After measuring peak
  • #12433: Limit line file units do not scale when changing the unit shown in the editorbox
  • #12454: Allow that \n as only terminator is used by mk messtechnik Motion detection
  • #12455: Extend the number of channels in mk messtechnik Motion from 4 to 16
  • #12456: Use a switchmatrix for the mk messtechnik Motion detection, to only have detection during the dwelltime
  • #12461: Error at second rotation of Frankonia FC05 turntable
  • #12474: 2021.3.6 version hangs during a singleband immunity test
  • #8094: Markers in MB Emission tests are shown twice
  • #8095: RadiGen RGN 4 kHz start frequency option
  • #11835: Update nlohmann json library C++
  • #12007: Driver: Tabor Electronics WW5061 signal generator
  • #12014: Device driver: R&S SMM100A
  • #12020: Signal Generator Rohde&Schwarz SMCV100B
  • #12061: RPC server unavailable + out of memory exceptions when generating reports
  • #12076: Generic limit line inclusion in generated reports for SB tests, such as EUT attenuation
  • #12166: Report generator add keywords "||<type> TEST LEVEL||" for multiband test levels
  • #12210: More digits (than in the past) for the fieldstrength are reported to CARAD
  • #12235: Driver: Teseo SOPM306L
  • #12264: Cannot change Baudrate of HI-6105 probe
  • #12330: Error during quasi measurement, because selecting AUTO RBW is not allowed
  • #12341: Antenna polarity changing problem controller FC06.1
  • #12342: The STOP button of the Antenna Height does not response for the Frankonia FC06.1
  • #12346: RI false peaks are detected for inputs not matching with the configured unit in the limit line
  • #12349: Amplifier linearity forward power step not calculated correctly
  • #12365: Radiated emission test is not working
  • #12366: Create the printout template for the calibration harmonics test.
  • #12369: Remove the ISXDL.DLL from DRIVERS.EXE
  • #12376: Read correct probe HW version
  • #12377: The STOP Button does not respond on the Frankonia FC06.1
  • #12379: Report generator: Excel hangs while generating report
  • #12380: Radiated Emission Error With RSA5065N
  • #12384: Error at end of peak measurement, because selecting AUTO RBW is not allowed
  • #12388: Unexpected invalid software key after new RadiMation install.
  • #12393: Sweeptime error.
  • #12394: SMA100A error
  • #12396: Error during final peak measurement.
  • #12397: Error during QP measurement.
  • #12398: Error during QP measurement.
  • #12411: Error about auto sweep time.
  • #12432: Stopping an AdvancedTurnTable device driver, starts moving again after stopping
  • #12435: Frankonia FC06 series returns polarization in degrees instead of radians
  • #12437: Read of SYST:ERR? from Frankonia FC series happens much later
  • #12445: Signal generator driver SMCV100B
  • #12450: SMA100A error
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2021.3 .
