New version: RadiMation Version 2022.2.2
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2022.1.4 version.
This version 2022.2.2 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2022.2.2 release of RadiMation can now be downloaded from the Raditeq website. Image
The following features/drivers are added to RadiMation 2022.2
  • #9626: Driver: ETS-Lindgren 2090
The following issues are fixed in this 2022.2.2 version (compared to the 2022.1.4 version):
  • #12686: Wrong test level if order is tick checkbox/change testlevel.
  • #12957: The Note and Units buttons are not shown on the UFA result window.
  • #12988: The maximum tolerance of the UFA calculation is not shown if it is all below the accepted tolerance
  • #12989: Wrong unit is shown at maximum deviation frequency on printout of uniform field area calculation.
  • #12996: Reading a binary block buffer results in a time out when using VISA Socket communication
  • #12999: N9322C Fails
  • #13000: N9322C Fails
  • #13002: Remove code related to HP3478A from Fluke 8840 driver
  • #5750: Improve the printout template of UFA calculation
  • #6170: Add support for IEC 61000-4-16: conducted immunity: common mode disturbances in the frequency range 0 Hz to 150 kHz
  • #12766: Add report button to the calibration result window
  • #12768: Add configuration options for the statistical information to the UFA calculation configuration dialog
  • #12816: Attenuation gain system calibration does not report the calibration level when opening the .CAL file
  • #12920: Switch to new text generation engine.
  • #12948: The dropdown list with pre-filled tolerances is unlogical
  • #12949: The red maximum error line in the UFA graph should be using the value as specified for the accepted tolerance
  • #12950: Accepted extended tolerance should not be smaller than accepted tolerance
  • #12951: Also include an 'Extended maximum error' graph to the UFA calculation graph
  • #12952: Selected template and report filename are not remembered after report is generated for UFA
  • #12954: A default filename and location for the report of a calibration file is not provided if the TSF file of the UFA calculation was not saved
  • #12955: Unclear what the numbers on the UFA calculation result are indicating
  • #12956: The maximum deviation of the UFA calculation is shown with too many digits
  • #12958: Optimized UFA calculation drops unexpected points
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2022.2 .
