New version: RadiMation version 2023.1.5
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2023.1.4 version.
This version 2023.1.5 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2023.1.5 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2023.1.5 version (compared to the 2023.1.4 version):
  • #13707: SV: RadiMation object null reference error when using the export functionality
  • #13716: RadiCentre version check Driver
  • #13720: Test Keysight IO viFLush returning buffermask of value 128 using pre-release build
  • #13721: Error in communication with Power meter
  • #13723: When a RadiPower USB is unplugged from the PC, no error is shown in RadiMation
  • #13728: EP601 Does not return correct field when using as ad input
  • #13732: Amplifier goes in operate before zero off probe
  • #13733: Correction of ep601 at 60 kHz is sent as 50 kHz
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2023.1 .
