New version: RadiMation version 2023.1.6
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2023.1.6 version.
This version 2023.1.6 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2023.1.6 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2023.1.6 version (compared to the 2023.1.5 version):
  • #13580: EP600 times out if the binary data returned contains a new line character
  • #13666: Provide a more generic 'attenuator' and 'pulse limiter' device driver
  • #13674: EMI Schaffner SCR3502 measures high peak values while measuring in the noise
  • #13692: Invalid message when removing input from TSF
  • #13709: TDEMI Cancel don't work in remote control
  • #13744: Logging mode is not supported by this powermeter.
  • #13748: Singleband Conducted immunity fixed voltage checks for a CI mill cal data document
  • #13756: Include check in firmware update if RadiLink is connected to the external power supply
  • #13768: Fixed step count stepper, only tests the first and last frequency of a band
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2023.1 .
