New version: RadiMation version 2023.2.5
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2023.2.4 version.
This version 2023.2.5 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2023.2.5 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2023.2.5 version (compared to the 2023.2.4 version):
  • #13291: Read all trace data when multiple detectors are active for a TDEMI
  • #13512: Error of invalid process is not shown anymore after SHIFT+Advanced click
  • #13536: Radimation 2022.3.6 crashs after each test when using two dongles.
  • #13764: SG386 pulse modulation
  • #13813: RadiMation hangs at the end of the test when multiple dongles are connected to the PC
  • #13920: Driver request: Stanford Research SG386 RF Signal Generator
  • #14005: Rigol RSA series: Additional sweep is taken after QP detector is activated to allow to level to correct amplitude
  • #14010: Problem with RadiMation and the polarisation of the Frankonia FC06
  • #14064: Rigol RSA series: Additional sweep is taken after QP detector is activated to allow to level to correct amplitude
  • #14111: Driver: ETS-Lindgren EMSense 7007-203
  • #14117: Apply cable correction to the magnetic field calibration
  • #14121: Driver: A-info DS-3100
  • #14122: Driver: A-Info LB-OH-650-10-C-SF
  • #14123: Driver: A-Info LB-2080-SF
  • #14124: Driver: Aeroflex 2025
  • #14125: Driver: Agilent Technologies 83731A
  • #14126: Driver: A-Info 62EWGS-A1
  • #14127: Driver: A-Info 90EWG3.5-T02-A1
  • #14128: Driver: EMC Partner ESD3000
  • #14130: Driver: Tekbox current probes
  • #14131: Driver: Tekbox Bulk current injection devices
  • #14133: MCU antenna tower position progress calculation issue
  • #14136: Driver: Injection device: Schloeder EMCL-20 and Schloeder EMCL-35
  • #14148: High attenuation required for measuring the fundamental results in upper harmonics being measured in the noise.
  • #14149: Adjust drivers to use the correct name for A-INFO
  • #14154: Rigol DSA832: Additional sweep is taken after QP detector is activated to allow to level to correct amplitude
  • #14156: Can HTTP communication be used to retireve information from JSON
  • #14160: Rigol DSG3065B does not support SYST:ERR?
  • #14161: Textronix AFG3251C reports event messages as errors
  • #14166: HI-6105 cannot save settings when pressing the OK button
  • #14176: CWS500 as receiver does not work
  • #14177: Object reference error opening Graph Export window
  • #14186: Error when using RS PRO analyzer as power meter
  • #14194: Data returned from Tektronix TDS oscilloscopes are calculated using 10 vertical divisions
  • #14194: Improved selection of to be transferred waveform from older Tektronix TDS oscilloscopes
  • #14195: Driver: RadiSense RSS2010M
  • #14199: HP E4419A cannot be found because the identification string cannot be changed
  • #14201: EMSense 7007-203 drivers
  • #14218: Wrong settings are sent to the VDI device
  • #14223: HP E4419A dual power meter error during zero operation
  • #14224: Process (PID number) not found after closing Notepad
  • #14225: Frankonia FC06.1 wait after height change to finish INIT procedure
  • #14226: Manual EFT configuration does not indicate the unit in which configured values are expressed
  • #14229: Driver: Tekbox TBMA4
  • #14230: Driver: Tekbox TBL 5032-3
  • #14232: Driver: Kalmus 320 FC
  • #14233: Driver: Kalmus 711-FC-CE
  • #14234: Driver: Teseq T800
  • #14235: Driver: FCC-801-M2-50A
  • #14236: Driver: FCC-801-M3-16A
  • #14237: Driver: FCC-801-M5-16A
  • #14238: Driver: EM Test ESD 30
  • #14243: Driver: Prana N-MT500DC
  • #14245: Magnetic field test according ISO 11452-8 time outs when using the Configurable multimeter driver
  • #14251: Adjusted start frequency to 9 kHz of Raditeq GTM0250A, GTM0500A and GTM1000A
  • #14255: Powermeter Fail
  • #14256: Regulation of initial step of a non linear amplifier is now using the configured default gain
  • #14259: HP4418 added option to enable the step detector and send the sense speed
  • #14261: Raise error if the selected filter setting is not allowed for current RadiPower firmware
  • #14262: Driver: Hameg 8135
  • #14263: R&S SMH Allow configuring of 10kHz-2GHz range
  • #14265: Standard socket port of the Rigol RSA-series is port 5555
  • #14267: Fix Strange layout of stirrer configuration panel
  • #14268: Select tuned mode as the default stirrer type
  • #14275: Driver: Boonton 4220 powermeter
  • #14287: Driver: IFI T188-50
  • #14288: Driver: Klein+Hummel SA602 amplifier
  • #14289: Driver: OPHIR RF 5041
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2023.2 .
