New version: RadiMation version 2024.1.4
We have released an updated version of the RadiMation software, which includes several improvements and fixes for problems that have been detected since the release of the 2024.1.3 version.
This version 2024.1.4 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation at for example a separate PC or laptop with your setup and with your measurement equipment, before you are going to use it for daily operation.
The new 2024.1.4 release of RadiMation can now be downloaded from the Raditeq website. Image
The following issues are fixed in this 2024.1.4 version (compared to the 2024.1.3 version):
  • #14904: 10 second timeout is prevented when Maturo FCU clamp mover starts moving
  • #14576: Communication improvements with the Boonton 4220(A) power meters
  • #14944: Improvements to starting virtual instruments tests
  • #14947: Application note 158: How specific devices can be excluded from the table of used equipment in the report
  • #14951: Detection of available axes on a Maturo FCU controller is improved
  • #14952: measurement issue by using ESR 26 Spectrum analyzer input 1
  • #14956: Fix loading calibration files created in 2024.1.2
  • #14959: Detection of the state of the preamplifier of the PMM9010 is improved
  • #14965: Value of retrieved preamplifier gain is shown correctly in RadiLog
  • #14967: Application Note 159: How to create nicely formatted tables in a report
The complete list of release notes can be found on: https://wiki.radimation.com/wiki/index. ... tes_2024.1.
