This version 2026.1.6 has been validated by our internal software quality checks. We strongly advise to test and verify (according to your quality system) this and each new version of RadiMation on, for example, a separate PC or laptop with your setup and measurement equipment, before you are going to use it for daily operation.
The new 2026.1.6 release of RadiMation can now be downloaded from the Raditeq website.
We always advise to thoroughly test each new RadiMation software version to determine if it works correctly in your situation with your equipment, before you use it for daily measurements. This is also a requirement for ISO 17025 accredited test laboratories. To enable customers to validate new software versions before implementing them, we have made it possible to install multiple versions of RadiMation side-by-side on a single PC. It is, of course, also possible to perform this validation on a separate PC or laptop.
Fixed issues and improvements
The following issues are fixed or improved in this 2026.1.6 version (compared to the 2026.1.5 version):
- #17665: Corrected the spelling of Connecticut Microwave Corporation in the coupler driver comment and device catalogue entry.
- #17656: Correct option detection for the R&S SMF100A signal generator
- #17653: Prevent intermittent crashes when opening polar and scientific graphs
- #17652: Fix Excel report generation when an empty template worksheet is removed
- #17645: Raditeq RPL3001R extended with move to start and end position option
- #17565: Prevent crashes during cleanup of virtual instrument graphs
- #11295: Improve report generator speed when inserting a large table into Microsoft Excel
The complete list of release notes can be found on: RadiMation 2026.1 release notes.
